ford 2810 fuel problems.... help
/ ford 2810 fuel problems.... help #1
garyginn
86 ford 2810
ive got a 2810 and im ready to pull my hair out trying to get fuel to the 3rd and last injector . 1&2 both bled out fairly easy AND IVE BEEN AT THE 3RD ON AND OFF FOR THREE DAYS. Anyone care to give advice , i could sure use it . Ive run diesels and heavy equipment for 40 yrs . this lil tractor has me whooped.
/ ford 2810 fuel problems.... help #2
Why are you having to bleed it? Did you run it out of fuel? Or did it just stop on you? You need to tell us more than just the model and that you can't get fuel to the #3 injector. Have you checked for blockage in the fuel delivery?
/ ford 2810 fuel problems.... help #3
Is it squirting from the pump.??
The cam ring inside the pump may have a couple of smashed lobes.??
Do u know about the filter under the pumps inlet nut.??
If not, google is your friend.
The filter may b clogged.??
Good luck
