Ford 2600 water leak
   / Ford 2600 water leak #1
bf15
none yet
Hey guys,
Wondering if any of you have seen a steady flow of water leaking below the water pump on a ford 2600 before.
Trying to determine if its a bad leak coming out or a weep hole, or a cracked block
Tractor did not over heat or anything and the fan is not wobbly.
Ill be taking the hood off to get a better look later today, just wanting to know if this is the normal sign for a failed water pump
   / Ford 2600 water leak #2
Many water pumps have a weep hole outside of the seal in the bearing end of the water pump to let you know it's time to replace the pump before the bearing goes clear out.
Does anyone know where i can download a service manual that has the cooling system, i know how to get it out and such but am looking for torque specs and such. I bout one that claimed to be a service manual, but it ended up being a addon piece to go into the service manual.
Id like to make sure i get the right thing.
   / Ford 2600 water leak #5
Use standard hardware torque specs. All the hardware you will be removing and installing will be Grade 5.
Thanks for the help, got it replaced and running without issue. I cleaned off about 25 years worth of dirt, and oil while i was at it.
Next phase will be fixing all the hydraulic leaks abd changing the fliuds out.
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
2012 WABASH 53x102 DRY VAN (A53426)
2012 WABASH 53x102...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2014 716PT Homesteader 7'x16' Box Trailer (A52384)
2014 716PT...
