ford 2120 Hydraulic problem with loader & 3 point & starting
   / ford 2120 Hydraulic problem with loader & 3 point & starting #1
boatmoter
plant city florida
john deere 212// john deere 320 // ford 2120 loader
Hi All, have a ford 2120, has the shuttle shift, loader - 3 point, the hydraulics seem to quit working on it,drives fine, then I will bleed the hydraulics and the lifts work fine, until I let it sit for a few days,then I have to bleed em again to get them to lift, it is also hard to start, but runs great and plenty of power and no blow-by or smoke, has low hours on it, does this engine have glow plugs? the filters have been replaced and filled with Hydraulic fluid, no difference,same problem. has 2 engine mounted pumps, both have been removed and inspected,see no problems, any suggestions or related problems with a fix??
   / ford 2120 Hydraulic problem with loader & 3 point & starting #2
My NH1920 (little brother to 2120) has glow plugs that are activated by turning the ignition switch backwards (counterclockwise) which runs a timer for about 10 seconds for the glow plugs. Wrong type of hydraulic fluid can cause foaming and generate this problem. Might check your center tank dipstick for foam.
See:ford 2120 hydraulics,stops working
Thanks for the reply, I will check it..
Kubota BX25D (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
