ford 2120 Hydraulic problem with loader & 3 point & starting
/ ford 2120 Hydraulic problem with loader & 3 point & starting #1
boatmoter
plant city florida
john deere 212// john deere 320 // ford 2120 loader
Hi All, have a ford 2120, has the shuttle shift, loader - 3 point, the hydraulics seem to quit working on it,drives fine, then I will bleed the hydraulics and the lifts work fine, until I let it sit for a few days,then I have to bleed em again to get them to lift, it is also hard to start, but runs great and plenty of power and no blow-by or smoke, has low hours on it, does this engine have glow plugs? the filters have been replaced and filled with Hydraulic fluid, no difference,same problem. has 2 engine mounted pumps, both have been removed and inspected,see no problems, any suggestions or related problems with a fix??
/ ford 2120 Hydraulic problem with loader & 3 point & starting #2
My NH1920 (little brother to 2120) has glow plugs that are activated by turning the ignition switch backwards (counterclockwise) which runs a timer for about 10 seconds for the glow plugs. Wrong type of hydraulic fluid can cause foaming and generate this problem. Might check your center tank dipstick for foam.
See:ford 2120 hydraulics,stops working
Thanks for the reply, I will check it..
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
1982 LOADSTAR LS25LB 96"X30' DOVETAIL TRAILER (A59823)
1982 LOADSTAR...
Case TV320 (A60462)
Case TV320 (A60462)
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2019 Toro Dingo TX525 Mini Skid Steer (A60462)
2019 Toro Dingo...
