ford 2000 tractor charging system
   / ford 2000 tractor charging system #1
mfalker
corfu ny
ford 2000
How do you change from a 6 volt to a 12 volt charging system?
   / ford 2000 tractor charging system #3
sounds like you have a 4 cyl gasser 62-64 prior model 2000, as the diesel 62-64 was 12v already, and all 3 cyl jobs were 12v.
so that means you have a 6v gen and reg.
2 easy options.
buy a 12v gen and reg for a diesel 62-64 prior model... or buy a delco 10si 3 wire alt.
the 12v gen / reg are direct swap outs.. just buy a napa ic14sb coil to replace your 6v ign coil.. and get new lamps.
if the alt.. there is a tisco kit for brackets.. or make your own.
on alt setup, run charge stud to the wire on the old reg that was labeled bat.
the alt has a lil 2 prong slot.. labeled 1 and 2
make up a jumper wire with a spade connector and ring terminal and connect 2 to charge stud.
make up another wire and run from 1 to the ignition switch.. but buy a lamp holder and run the wire connection thru that lamp holder. lamp should be a 194 lamp.. like a trailer marker.
ie.. wire from alt 1 to one side of lamp holder, other side of lamp holder to same wire on ignition switch running to coil.
key on = lamp on, once you start and get over 400 rpm or so, lamp goes out and chargig starts.
that easy.
ps.. get correct pulley on alt for belt.. etc..
thank you for your fast response!!!will pass this info on to my husband and see how things go...thank you again
thank you!!!!!!
   / ford 2000 tractor charging system #6
post pack with any questions or if you hit a snag.
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
1992 BYQ Boat and Trailer (A56859)
1992 BYQ Boat and...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56435)
2023 Kubota...
402 (A52706)
402 (A52706)
