Ford 2000 timing
   / Ford 2000 timing #1
kennyl123
Bronze Member
Pollock, LA
Ford 2000
Hi all, I need some advice on my ford 2000 I removed the front cover and changed the gasket and seal and water pump. I took blots out of fuel injector gear but didn't think I let it turn any but I put all back together and it wouldn't crank tore it back down to check timing and I cant get the camshaft gear and the camshaft drive gear marks to match up , Idid not fool with those gears what happened to it ? or how do I get it back in time . I really don't know how to tell if # 1 piston is tdc on power stoke. PLEASE HELP
   / Ford 2000 timing #2
this is a 3 cyl diesel 2000 or a 4 cyl diesel 2000?
guessing 3 cyl by you taking bolts out? right?
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
2009 KENWORTH T800 (A50854)
2009 KENWORTH T800...
2009 MACK CXU613 DAYCAB (A50854)
2009 MACK CXU613...
2019 FORD F-150 (A50854)
2019 FORD F-150...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
