Ford 2000 relief valve enquiry
   / Ford 2000 relief valve enquiry #1
MartyJay
Victoria, Australia
Ford 2000
Long time reader / first time poster...!
I am in the process of rebuilding my Ford 2000 top lid and I believed I had ordered correct parts.
So far everything has been a 1 for 1 likeness..Until today.
I removed the pressure relief valve from the bottom of the hydraulic case and compared to the new supplied valve. There appears to be quite a bit of difference.
I am guessing I've ordered the wrong part. Can anyone assist? I believe by the serial numbers its a 1968 Ford 2000 (3cyl diesel).
Thanks in advance.
Marty
   / Ford 2000 relief valve enquiry #2
My thought is the valve design has been updated, we are talking about a nearly 60 year old machine. As long as the valve fits and it looks to me like it will, I would screw it in and run with it.
Thanks John0829. I've googled as much as I can and everything comes back with the same type of valve, so I'd say you're correct. At least its easy to get access to if I need to swap out.
   / Ford 2000 relief valve enquiry #4
Please let us know how it works out.
The parts manual indicates C7NN638E replaced C5NN638C, which I suspect was the original in mine.
I have hopefully one last question. Has anyone replaced the piston in the hydraulic cylinder with new o-ring and nylon ring?
I've watched a couple of videos on YouTube which are helpful, but it appears they could eventually push the piston in by hand.
I've got to tap mine in with a block of wood covering and gently tap with a hammer. It won't go down by hand and was very difficult to get out with the compressor.
Just don't want to put everything back in if this is an issue.
   / Ford 2000 relief valve enquiry #6
When I replaced the cylinder in my 850 I used the upgraded o-ring and backup ring but I cannot remember definitely how hard it was to push into the cylinder. Having said that it seems to me that after I got it started into the cylinder with a ring compressor it took some effort to push it down. I vaguely remember pushing it down with the handle of a hammer and kinda having to get behind it to do so, I think I do anyway but I do not recall just pushing it down with my fingers.
I would just make sure the cylinder is honed up good and smooth, lubed it up well and continue on with the installation.
Anyway I have had no issues with it mine and according to my records I replaced it back in 2009 when I rebuilt the pump and replaced the hydraulic lines internal to the transmission (not a fun job).
More info coming soon! (A50322)
More info coming...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53472)
2011 New Holland...
(1) Drum of Algicide (A51573)
(1) Drum of...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2015 KENWORTH T800 DAY CAB (A53426)
2015 KENWORTH T800...
