Ford 2000 governor question?
   / Ford 2000 governor question? #1
wraiths
Ok here goes after setting the idle on my tractor to 750 rpms, and lettng it run it wants to creep back up from 750 to around 1200 rpms as it sits and when shutting throttle off it doesnt always go back to idle you have to open and shut the throttle a few times before it will. It will start fine. Others said it could be the governor but I know nothing about the governor. What can you tell me about it and how to go about seeing whats wrong with it. Are there adjustments that can be made? The I&T manual I have is really vague on the governor. Thanks
   / Ford 2000 governor question? #2
3 cyl or 4 cyl. gas or diesel need to know first before u can get any help
sorry about that its a Ford 2000 3 cylnder gas.
Anybody know how to go about trouble shooting the governor. The pics in the repair manual I have are far from adequate and I dont know anything about the way it is supposed to look. By the way, I do know the governor on mine is the one with 2 arms. thanks
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2016 Volvo SD45 Smooth Drum Roller (RIDE AND DRIVE) (A50774)
2016 Volvo SD45...
1999 Chevrolet 1500 (A50121)
1999 Chevrolet...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2003 Ford E-350 16ft Box Truck (A50323)
2003 Ford E-350...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
