Ford 2000 cooling leak
   / Ford 2000 cooling leak #1
INDSAM
kelowna
ford
Hi every body I am looking to buy a ford 2000 but the owner told me that there is a leak when you pour fluid into the rad it right way start pouring from the bottom of the block what it could be some thing serious or just a small seal or so please advise thanks
   / Ford 2000 cooling leak #2
If it's toward the front of the engine it could be running down from a failed water pump.
   / Ford 2000 cooling leak #3
Not much to go on.
Is the tractor the older 4 cylinder version or the newer 3 cylinder model?
Bottom of the block - where does it leak?
Front? Rear? Left? Right?
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
378670 (A51573)
378670 (A51573)
New Long Forks (A53002)
New Long Forks...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
