Ford 1910 PTO Issue
/ Ford 1910 PTO Issue #1
danrick
Leon, TX
Ford 1910
I have a Ford 1910 tractor which the PTO disengages when trying to shred. I was curious why this may be occuring? Should I add hydraulic fluid? the PTO operated fine but after shredding for a while it began disengaging.
The tractor belongs to my father so I do not have much knowledge about it. If someone could maybe help with a some information that would be a huge help.
/ Ford 1910 PTO Issue #2
Is the rotary cutter (shredder) the only PTO driven implement that causes problems?
Does the cutter run for a while before it disengages?
Before any disassembly, start troubleshooting the linkages. I don't know if the PTO is hydraulically driven, but it can't hurt to ensure the hydraulic fluid is at the correct level.
You may have better responses posting this in the New Holland forum or the general Owning/Operating or Parts and Repairs forum...please select one...don't double post (that causes confusion)
/ Ford 1910 PTO Issue #3
check for in / out play on the pto stub shaft..
post back
2016 Nissan Sentra Sedan (A59231)
2016 Nissan Sentra...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
2013 Dodge Charger Sedan (A59231)
2013 Dodge Charger...
2020 Hino Garbage Truck (A60352)
2020 Hino Garbage...
