ford 1910 brakes
   / ford 1910 brakes #1
Jeff Gammon
Paragould Arkansas
1910 Ford
Anybody ever replace the brake shoes on their 1910? How bad of a job is it? Do you just pull the fenders, then take the bolts out of the housings, and that exposes the drums?
   / ford 1910 brakes #3
go ahead and hunt them down and price them so you'll get over the chest pains before you start!
   / ford 1910 brakes
Iave read on here where folks have talked about relining them their selves
   / ford 1910 brakes #6
Good thread. This been one of the subjects I've been Searching, searching (For so long) Searching (Searching) Searching, searching* but had come up empty. Hope some of the veterans here can shed some light.
My question is can they be adjusted a time or two after you run out of pedal before having to re-line / replace?
* Performed by Luther VanDross, written by Mauro Malavasi, Paul Adrian Slade.
   / ford 1910 brakes
I haven't been able to come up with much either. I still have some brakes, but am going to take them apart when I get the time. When I do Ill take some pics of the process and post them
   / ford 1910 brakes #8
Rick is right on...if they need replaced have them relined, it's almost always much cheaper. However, several years ago I took the shoes out of my Mitsubishi with the intention/thought that it was time to have them relined, only to find there was plenty of shoe material left, they were just heavily glazed. A good drum and shoe cleaning with a wire wheel ( wear a mask!) and they worked like new again. Not saying your issue is simply glazing but if you get it apart and find the shoes have plenty of lining left but you've been suffering poor/ non existant brake performance they are probably simply glazed.
As far as Square1's question about readjusting them- I say absolutely, as long as they aren't so worn that rivets etc, are contacting the drum, adjust them. Just be sure you leave the proper pedal free play.
   / ford 1910 brakes #9
I've just volunteered to help with maintenance of the village green - yes , cricket ! They have a Ford 1910, I have sorted the very loose seat mounting, next is the handbrake. I was told replacement 'pads' for the handbrake would cost £200 / $250 , but surely these are brake shoes and you could rivet new ones on for a lot less ??
   / ford 1910 brakes #10
Welcome to TBN! The shoes are not riveted, but glued to the shoes. Your price is correct for each shoe x 4 through New Holland. That is why relining is suggested. Possibly there are aftermarket options, but what I found is $213/pair here.
The handbrake is actually just a brake lock of the foot pedals.
Digmaster DM100 Mini Excavator (A49251)
Digmaster DM100...
Hydraulic 190 Angle Blade (A49251)
Hydraulic 190...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2005 Land Pride RCM5015 (A47164)
2005 Land Pride...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
