Ford 1910 770B loader question?
   / Ford 1910 770B loader question? #1
Welwood
Jacksonville, Florida
Ford 1910
I have a Ford 1910 with 770 loader that I am replacing the ridgid hydraulic lines
on the loader. Anyone have any tips/suggestions on start-up i.e. priming, air in lines etc.?
TYIA
   / Ford 1910 770B loader question? #2
After you get all of the lines on, overfill the hydraulics by 1/2 gallon and cycle the cylinders open and closed 4-5 times. They will bleed and purge themselves. Check your hydraulic level and adjust.
Thanks much TTech,
This is not usually my kind of luck, sounds easy enough to me. I assume you cycle running vs static, correct?
Thanks again.
   / Ford 1910 770B loader question? #4
Thanks much TTech,
Thanks again.
Yes, with the tractor running, cycle the lift and bucket cylinders several times.
Sorry, I realized after I asked it had to be running. Someone once said theres no such thing as a
stupid question............only inquisitive idiots.:D
   / Ford 1910 770B loader question? #6
No problem. One of those things that once you've said or read it, you realize what you actually said.
Lonestar Panels (A49339)
Lonestar Panels...
2015 Ford F-550 Reading Enclosed Service Truck (A46683)
2015 Ford F-550...
Hand Tedder (A49251)
ASSET DESCRIPTIONS & CONDITION (A45679)
ASSET DESCRIPTIONS...
Milestone 30" Seed Treater (A47369)
Milestone 30" Seed...
2008 Ford F250 Reading Service Truck (A46683)
2008 Ford F250...
