Ford 1900 with Shibaura 3 cyl engine....
   / Ford 1900 with Shibaura 3 cyl engine.... #1
BobG_in_VA
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
A friend is doing some engine work on his 1900....the service manual says that the cyl head bolt should be torqued to "43 lbs"....this can't be...as it was probably 120 ft/lbs to get it off....anyone have any idea what the torque values are for this engine's cyl head?? (PS: I've done pretty extensive searches and found others have run into the same thing, but no one has come up with an answer...any help is appreciated!) BobG in VA
   / Ford 1900 with Shibaura 3 cyl engine.... #2
i realize this is an old thread, but i followed my manual as well only to discover that after replacing my head gasket, all my head nuts were loose.
wondering what i really should have tightened them to rather than the 43 ft lbs
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
FRONTIER FAV20 LOT NUMBER 68 (A53084)
FRONTIER FAV20 LOT...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2025 High Country Cargo 7x16 Enclosed Trailer, VIN # 7FWBE162XS1035597 (A51572)
2025 High Country...
New Holland 55 Pull Type Rake (A51573)
New Holland 55...
