BobG_in_VA
Veteran Member
- Joined
- Jul 4, 2003
- Messages
- 2,002
- Location
- Central VA, USA
- Tractor
- Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
A friend is doing some engine work on his 1900....the service manual says that the cyl head bolt should be torqued to "43 lbs"....this can't be...as it was probably 120 ft/lbs to get it off....anyone have any idea what the torque values are for this engine's cyl head?? (PS: I've done pretty extensive searches and found others have run into the same thing, but no one has come up with an answer...any help is appreciated!) BobG in VA
