Ford 1900 muffler
/ Ford 1900 muffler #1
seanbutler
Wakefield, Quebec
Ford 1900
Hi all,
This is my first post. I just bought a Ford 1900 last August. Seems like a sturdy workhorse (1200 hours) but one thing I've noticed is parts are hard to come by and expensive. I've so far had to replace the front tires and buy a ROPS for it. Now I'm looking for a new muffler. All the aftermarket ones I see online, as well as the one offered by the local NH dealership, don't work on my tractor because it has a loader on it and the inlet pipe of the muffler (where it does a 90 degree turn upwards) comes out too far and hits the frame of the loader. All these new mufflers have 15" inlet pipes, whereas the one currently on my tractor is only 6" long. Does anyone know where I can get a muffler with a shorter inlet pipe?
Alternatively, I could try welding the old muffler. It's totally rusted out where the inlet pipe goes into the muffler, but it might be possible.
I already bought a new muffler, not realizing it wouldn't fit, so another option would be to cut out a section of the inlet pipe of this muffler and reweld it back together. I'm kind of partial to this idea, if it would work, as I've already paid for shipping and customs fees (it was from the US) and I would have to pay more to ship it back to the seller to get a refund.
Any advice most appreciated!
Sean
/ Ford 1900 muffler #2
I have a Ford 1600 that has 3,600 or so hours on it that runs mint. I did need a head gasket and a water pump, both I found online cheap. Yes, some parts from the dealer can be pricy, but i doubt a JD or Kubota of the same vintage are in any different price market. I think the old Fords were very underated. On my 1600, the muffler is turned 90 degrees so that the exhaust blows forward, near the grill. Not sure if turning it would clear on your 1900?
/ Ford 1900 muffler #3
Hi all,
Sean
Cut your new muffler, and weld it, or have somebody else, weld it back together for you.
What else would you possibly do with it?
Put it on the garage shelf for 20 years?
/ Ford 1900 muffler
Glad to know you haven't had trouble with parts. I think for the muffler no matter which way I turn it, that loader's still going to be in the way.
/ Ford 1900 muffler
I could return it and get my $100 back, but I'd have to pay for shipping.
/ Ford 1900 muffler #6
Maybe a muffler shop could make the mod you need, or an adapter. Got any pix of the problem? Or if the old and new mufflers?
Jim
/ Ford 1900 muffler #7
1900 is a great tractor. Cut the new muffler and weld it up. Should be easy to mig it. Cut fairly close to the mounting flange to disguise the repair.
/ Ford 1900 muffler #8
I had a 1900 and cut down to the stub and had a shop weld another small muffler on it. Worked fine.
2021 John Deere Gator TX4x2 Turf Utility Cart (A64194)
2021 John Deere...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2012 Freightliner M2 106 S/A 14ft. Cab and Chassis Truck (A64194)
2012 Freightliner...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
