ford 1900 injector pump help
   / ford 1900 injector pump help #1
paulyny
Bronze Member
Trying to get my father in laws ford 1900 running. Tractors been sitting at least 5 years. Change the fluids and fuel. Problem is injector pump. Only have fuel coming out of one of the injectors.I know this is probably an expensive repair but I did see a company online a few years ago that rebuilt these Kiki pumps. Any advice greatly appreciated.
   / ford 1900 injector pump help #2
I'll admit upfront I know as much about diesel injection systems as I do about the surface of the moon. Why, if your getting fuel to one injector do you suspect the pump? I'd start with the non performing injector(s).
   / ford 1900 injector pump help #3
Injection pumps won't pump air. Did you bleed the fuel system from tank to injectors? There's a sequence you need to follow.
   / ford 1900 injector pump help #4
1900's are hard to bleed like someone else said bleed from tank to pump first, then injectors.
Good luck
If I remember well, I referenced afford 1710 service manual. Im gonna give it another try.
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A51039)
2023 MAXXD TDX...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
