Ford 1900 and 3 point log splitter - weak pressure from remote line
   / Ford 1900 and 3 point log splitter - weak pressure from remote line
JJ, thanks for your continued posts. I'd say there's a 25% difference (will guage this weekend) between extend and retract. It will split anything in the extend stroke but needs to take smaller bites to split on the retract. Let me fiddle some more this weekend and I'll respond to your ques. Thanks again. Chuck
   / Ford 1900 and 3 point log splitter - weak pressure from remote line #12
Did you ever check the relief pressure on the remote and log splitter valve?
What is your tractor relief pressure?
Cylinder Push / Pull Force
Bore Size 4 inches
Rod Diameter 2 inches
Pump Pressure 3000 PSI
Push Force 37,699 lbs
Pull Force 28,274 lbs
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
1267 (A50490)
1267 (A50490)
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
