Ford 1900 and 3 point log splitter - weak pressure from remote line
   / Ford 1900 and 3 point log splitter - weak pressure from remote line
JJ, thanks for your continued posts. I'd say there's a 25% difference (will guage this weekend) between extend and retract. It will split anything in the extend stroke but needs to take smaller bites to split on the retract. Let me fiddle some more this weekend and I'll respond to your ques. Thanks again. Chuck
   / Ford 1900 and 3 point log splitter - weak pressure from remote line #12
Did you ever check the relief pressure on the remote and log splitter valve?
What is your tractor relief pressure?
Cylinder Push / Pull Force
Bore Size 4 inches
Rod Diameter 2 inches
Pump Pressure 3000 PSI
Push Force 37,699 lbs
Pull Force 28,274 lbs
2008 FREIGHTLINER FLD120 SD DAYCAB (A50854)
2008 FREIGHTLINER...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
