ford 1720 rear axle housing
   / ford 1720 rear axle housing #1
fuccillo111
dynamark 16/42
not sure year, but i think its a 1989, 4x4. my stepdad needs to know it the rear axle housings are interchangable. for what ever reason he wants to swap the right side with the left side. also how will this, if at all, affect the rear brake set-up? thanks in advance.
   / ford 1720 rear axle housing #2
SBA326342310 is the part number for the brake & wheel shaft case, as they call it. Over $800 new most anywhere, I suppose. Same part number for both sides, so they are interchangable. If the thing is assembled correctly, the brakes will work as good or bad after swapping the housing as before.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
250 GALLON FUEL TANK (A51247)
250 GALLON FUEL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
