ford 1720 rear axle housing
   / ford 1720 rear axle housing #1
fuccillo111
dynamark 16/42
not sure year, but i think its a 1989, 4x4. my stepdad needs to know it the rear axle housings are interchangable. for what ever reason he wants to swap the right side with the left side. also how will this, if at all, affect the rear brake set-up? thanks in advance.
   / ford 1720 rear axle housing #2
SBA326342310 is the part number for the brake & wheel shaft case, as they call it. Over $800 new most anywhere, I suppose. Same part number for both sides, so they are interchangable. If the thing is assembled correctly, the brakes will work as good or bad after swapping the housing as before.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
PALLET OF MISC PUMPS (A51248)
PALLET OF MISC...
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
