Oil & Fuel Ford 1720 Hydraulic Fluid & Filter(s) change
   / Ford 1720 Hydraulic Fluid & Filter(s) change
You should really have a FORD manual for your 1720. It has a 2 stage dry clutch.
There is a FORD OEM (copy) manual available from ...themotorbookstore.com.... $41.95
If you are you referring to the I&T Shop Service Ford Shop Manual (# FO-46)....I have that.
Unfortunately & challenging for me, my reading/comprehension ability can be difficult at times......just as I inferred in Post #4, about the three drain plugs - it was in my book, I just couldn't/didn't see or read it correctly until RickB pointed it out.
Nevertheless, THANKS for the suggestion, Fried1765! :thumbsup:
BarnieTrk :)
   / Ford 1720 Hydraulic Fluid & Filter(s) change #12
The Ford 1720 tractor utilized both a single and double clutch on this model.
.....I see both Tie-Rod ends are in need of replacement!
Today's task: tie rod end replacement. Any suggestions, tips, short cuts?
BarnieTrk
Yep, makes good sense. Thanks for the reminder, RickB! :drink: BarnieTrk
Fellas,
The hydraulic fluid and filter change went fine. While I was at it, I also changed the motor oil and filter.
Thanks again for everyone's input!! :thumbsup:
BarnieTrk
Just wanted to follow up --- As I had hoped, the squealling that occurred when I actuated the front bucket controls has since stopped since the hydraulic fluid / filter change. Now when I operate the levers, things move without all the squealling! NICE!
Thanks again for everyone's input and help!:dance1:
BarnieTrk
30KW GENERATOR (A58214)
30KW GENERATOR...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
Generac XG8000E Generator (A55973)
Generac XG8000E...
CFG Industrail MX15RX (A53317)
CFG Industrail...
HAND SAWS (A58374)
HAND SAWS (A58374)
JOHN DEERE 12' BOX SCRAPE (A52708)
JOHN DEERE 12' BOX...
