ford 1715 clutch question
   / ford 1715 clutch question #1
a24vc
Im putting a clutch in a ford 1715. Im looking to see if anybody knows what the torque specs are on the bolts for the pressure plate to the flywheel? Any help would be appreciated! AB
   / ford 1715 clutch question #2
Howdy,
below is a scan of IT manual. It does not list 1715 there but does list 1710. Most probably you have a dual clutch set up same as below. They don't show torque rating for single clutch but for double is 18-25 ft-lbs
   / ford 1715 clutch question #3
This is an old thread but I need the torque specs of the pressure plate and flywheel on the 1715 'single clutch'.
All I can find is a 1310 with 18lbs for pressure plate and 50lbs for flywheel
Thanks in advance
   / ford 1715 clutch question #4
As long as you torque equally in a criss cross fashion and about 1310 specs you should be okay. I think 1300, 1500 and 1700 have actually same dia clutch plate. I checked it once but my memory is a bit cloudy now. if the torque is a bit more and uniform you should be okay. Gooten-n-tight and uniform is good.
   / ford 1715 clutch question #5
I have the 1715 supplement and it shows,
Flywheel mounting bolts 43.4-51 lbs.-ft.
Clutch mounting bolts 16.6-21 lbs.-ft.
   / ford 1715 clutch question #6
Thanks
FOREST CITY 13' CHOPPER (A52708)
FOREST CITY 13'...
1301 (A58374)
1301 (A58374)
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
PALLET TOTE OF MISC CATCH PANS & HEATER PARTS (A58374)
PALLET TOTE OF...
