ford 1715 clutch question
   / ford 1715 clutch question #1
a24vc
Im putting a clutch in a ford 1715. Im looking to see if anybody knows what the torque specs are on the bolts for the pressure plate to the flywheel? Any help would be appreciated! AB
   / ford 1715 clutch question #2
Howdy,
below is a scan of IT manual. It does not list 1715 there but does list 1710. Most probably you have a dual clutch set up same as below. They don't show torque rating for single clutch but for double is 18-25 ft-lbs
   / ford 1715 clutch question #3
This is an old thread but I need the torque specs of the pressure plate and flywheel on the 1715 'single clutch'.
All I can find is a 1310 with 18lbs for pressure plate and 50lbs for flywheel
Thanks in advance
   / ford 1715 clutch question #4
As long as you torque equally in a criss cross fashion and about 1310 specs you should be okay. I think 1300, 1500 and 1700 have actually same dia clutch plate. I checked it once but my memory is a bit cloudy now. if the torque is a bit more and uniform you should be okay. Gooten-n-tight and uniform is good.
   / ford 1715 clutch question #5
I have the 1715 supplement and it shows,
Flywheel mounting bolts 43.4-51 lbs.-ft.
Clutch mounting bolts 16.6-21 lbs.-ft.
   / ford 1715 clutch question #6
Thanks
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2017 Snorkel S4732 Scissor Lift (A57453)
2017 Snorkel S4732...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
