Ford 1710
/ Ford 1710 #1
Roger A12
New London Ohio
8N Ford
Need help I have a ford 1710 with a bad motor will a 1910 fit or will parts from the 1910 fit the 1710. They look close might be only be the cylinder bores difference thanke
/ Ford 1710 #2
Interesting question. The bore and stroke are different, as well as the radiator. The overall tractor wheelbase is longer, the hood is longer. The engine would mate upm to the bell housing. Also, the 1910 used larger tires, so the ratios are different.
/ Ford 1710 #3
Interesting, more HP for bigger tires gear train could be the same, they might have moved the front axle to make longer wheel base and stretched the hood to make it look bigger. Thanks.
/ Ford 1710 #4
The New Holland web site has part diagrams with part numbers, if the part numbers match on both models you are good to swap.
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
John Deere 3010 (A64911)
John Deere 3010...
Vintage Grease Gun (A64912)
Vintage Grease Gun...
2013 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A66734)
2025 Wolverine...
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
