ford 1710 loader specs
   / ford 1710 loader specs #1
svt
First timer! I am looking to purchase a 1983 ford 1710,4wd,loader, I have been able to find all specs on the tractor except the ones on the loader. Load limit?, bucket height? If there is anyone out there that can help, i would appreciate it.
   / ford 1710 loader specs #2
The loader should be similar to the Ford model 7108 on my 1620. If so then the manual I have says that it has a 900# lift capacity, a lift height of 99", the bucket width is 5 feet rated at 10.9 cubit ft. The lift height is like the edge of the bucket in level position from ground level to a level bucket at max height (ie: excluding any roll back/curl on the bucket).
I have loaded tires and with the bucket full of wet top soil the rear gets pretty light. I need to add some rear end weight, like hang my brush hog on it, if I am going to be moving lost of damp dirt or clay.
If the loader is not a ford 7106 or 7108 you would need to find out what brand/model it is to get the spec's for it.
thanks for the info!
   / ford 1710 loader specs #4
My '85 1710 came with a SMC 84Q model FEL. My local NH dealer said that alot of dealers used the SMC (which is now owned by Alamo) and I emailed Alamo for a owners,service,& parts manual.They sent it via a PDF file. No charge.:D
   / ford 1710 loader specs #5
Hello to all I know this is a very old post. By any chance do you still have the pdf. On the loader SMC 84Q I just picked up a Ford 1920 with loader and it痴 hard to find any info on it especially a owners manual. Thanks all for your help
Miscellaneous Metal File Cabinets (A54816)
Miscellaneous...
Pallet of Vehicle Seats (A54816)
Pallet of Vehicle...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
2014 Chevrolet Impala Sedan (A56859)
2014 Chevrolet...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
