Ford 1710 hydraulics failure
   / Ford 1710 hydraulics failure #1
gregoryjwells
Argyle, tx
Ford 1710
I just purchased a Ford 1710 (model AL3136). The bucket is extremely slow to raise/lower. The former owner said he had tried to pull a stump out and the hydraulics have not been the same since. I have never worked on any hydraulic systems before and would appreciate any direction on how to start to determine what failed.
   / Ford 1710 hydraulics failure #2
Disconnect and reconnect you hyd hoses to the FEL. Sometimes they push apart under pressure just enough to slow them down.
   / Ford 1710 hydraulics failure #3
Install a hyd gage and use it to trouble shoot and analyze your hyd problems.
The relief setting might need some adjusting.
Some of the cyl seals might be worn, or a valve spool.
I'll research and report back. Thanks for the help.
That was it!
As I traced the lines back from the FEL to the quick disconnects, one of the lines came off just by me wiggling it a tiny bit. I snapped it back in and now have full lift/descent on the FEL. It's still a bit sluggish and slow, but this is a 30 year old machine after all.
Thanks for the suggestions.
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
90018 (A48082)
90018 (A48082)
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
Unused 2025 CFG MX15RX Mini Excavator (A49461)
Unused 2025 CFG...
