Ford 1710 Broken Steering Sector Gear Shaft
   / Ford 1710 Broken Steering Sector Gear Shaft #1
tedward4
Rochester, MN
'84 Ford 1710, '87 Ford LGT 14D
Wondering if anyone else has had this failure on their 1710:
You can see from the picture that the cracks propagated from the spline roots.
I mostly use the tractor with the loader so there's a little more load on the steering shaft than with no loader. It looks like the replacement part from NH is NLA so I had to try to fix it. After machining a vee, I TIG welded multiple passes (cooling the bearing surfaces between passes to keep them case hardened), then machined back to net shape. It's holding up so far.
   / Ford 1710 Broken Steering Sector Gear Shaft #2
Nice job fixing it.
   / Ford 1710 Broken Steering Sector Gear Shaft #3
Great job fixing it, hope it holds together for you! Looks like it's been cracked for some time before breaking.
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
