ford 1710 3pt ball joint's---need advise
   / ford 1710 3pt ball joint's---need advise #1
BigDog1956
Sault Ste Marie,Mi
Ford 1710 4x4 FEL-back blade-KK box blade
Hello Ya'll, I started doing a little sand blasting today and started on the swing arm's, and can see the ball joint's in the end of each arm (lower) are worn out, can't really tell by looking how to replace them, I see there are stub's offered that you cut off end and weld new end on (kinda pricey-I don't have a 220 welder) and there are just ball w/sleeve replacement, but I can't find any info about wich type I need or how to, Thank's for any advise !!!!!!
   / ford 1710 3pt ball joint's---need advise #2
The ones that come out have a horizontal slit in the lift arm. the ball is rotated sideways, 90 degrees from where it "works" and slides out. Those would be built in that configuration. The others, non replaceable, and I have a tractor with new ends PO put on, are as you say, chop off the ball plus about an inch and weld on new.
Thanks Texas, I will look closer tomorrow-but pretty sure mine are the one's that will have to be cut off and new end's welded on, dang I have regreted getting rid of my old 220v welder, Maybe I'll see what a cheaper 220v stick welder run's, geez to weld on 2 end's on both lift arm's they would prob charge 1/2 price of a cheap box welder ??? I have a 110v mig,,,but that won't come close...
2013 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2013 Volvo Semi...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A50323)
2006 Chevrolet...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
