Ford 1700
   / Ford 1700 #1
Laurens
Hello everybody, I have a ford 1700 and I would like to know where you have to fill up your oil level at the rear or is it 1 part from the oil level in the gearbox? I'm sorry for my bad english, I just want to know where you have to fill up the oil. Thanks a lot !!!!!
Greets, Laurens
   / Ford 1700 #2
The transmission and rear end share a common resovoir (approx. 23 quart capacity), checked and filled on top of the transmission.
There should be a dipstick attached to the plug. Mine is located on the right (top) side of the transmission just behind the shift lever.
Don't screw the plug in to check the level, just set it on the top of the hole and the level should not extend above the knurled surface on the dipstick.
Good luck.
   / Ford 1700
Thanks a lot !!!!
   / Ford 1700
Hello zoomie, can you help me again please ?? Do you know how many the 1700 weights? Please give it in kilograms because i dont know how many kg a lbs is. Thanks a lot !!!
   / Ford 1700 #5
Laurens,
My owner's manual lists the weight at 1140 Kg for the 4wd model (1065 KG for 2WD).
2021 Liebherr L556 (A52748)
2021 Liebherr L556...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A51572)
2004 International...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
