Ford 1700
   / Ford 1700 #1
Laurens
Hello everybody, I have a ford 1700 and I would like to know where you have to fill up your oil level at the rear or is it 1 part from the oil level in the gearbox? I'm sorry for my bad english, I just want to know where you have to fill up the oil. Thanks a lot !!!!!
Greets, Laurens
   / Ford 1700 #2
The transmission and rear end share a common resovoir (approx. 23 quart capacity), checked and filled on top of the transmission.
There should be a dipstick attached to the plug. Mine is located on the right (top) side of the transmission just behind the shift lever.
Don't screw the plug in to check the level, just set it on the top of the hole and the level should not extend above the knurled surface on the dipstick.
Good luck.
   / Ford 1700
Thanks a lot !!!!
   / Ford 1700
Hello zoomie, can you help me again please ?? Do you know how many the 1700 weights? Please give it in kilograms because i dont know how many kg a lbs is. Thanks a lot !!!
   / Ford 1700 #5
Laurens,
My owner's manual lists the weight at 1140 Kg for the 4wd model (1065 KG for 2WD).
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
