ford 1700
/ ford 1700 #21
Und de bottom.
/ ford 1700 #22
Chris, you made me drive the Ford to get the sun "right" - what a nasty trick!
I included this so you could compare the dash area.
/ ford 1700 #23
(paint this Ford blue and replace the name sticker...)
<font color=blue>...you mention KingCutter a lot - do you like them?...</font color=blue>
/w3tcompact/icons/grin.gif You would think I have stock in the company or something.../w3tcompact/icons/wink.gif
Lots and lots of value for the almighty dollar... Here's a good case where you actually get more than your moneys worth most of the time...
Kinda rare in today's world... /w3tcompact/icons/crazy.gif
/ ford 1700 #24
BTW, I rechecked your profile just for kicks - and noticed you had a big 1920. Here's a 2120 HSS I have been drooling over a bit at the same dealer where I was drooling over the Kubotas. I basically just drool a lot, I guess. It has the quick attach bucket on the Woods 1020 loader, with a second set of quick-connects up by the controls and a second smaller lever up next to the FEL control lever. It is very clean - 395 hrs. Priced at $18.5k, and has been there for a few months. It's a lot of tractor. Do you have any pics (haven't searched on your posts yet) of your 1920 - and maybe a little commentary on it - pro/con, or whatever?
/ ford 1700 #25
Wow - that's it, pretty much exactly, except for minor details in the hitch area. So is KingCutter building them for L&S, or vice-versa? I assume you are saying L&S gets them from KC......
/ ford 1700 #26
<font color=blue>KK specifies ~~300 ft.lbs... on mine I always had them about 500-600 ft.lbs.)</font color=blue>
Dare I scold a Star member? -- Congratulations by the way.
Please becareful overtorquing bolts. I would stick to the manufacturers recommendation, unless you are having a problem with it loostening. Either way, don't exceed the max recommended value for the fastener
I don't know what size the bolt in question is, but you can break any bolt with a big enough air wrench or cheater bar. There are plenty of places on the web to check the max torque for a particular bolt, grade 2, 5, 8 stainless & etc. Also found in many tractor & implement owners manuals.
Here's one I found <A target="_blank" HREF=http://www.thelenchannel.com/1torque.html> Bolt torque chart </A>
PS, this may be a big honking bolt & you are well within the recommended values.
/ ford 1700 #27
<font color=blue>...Either way, don't exceed the max recommended value for the fastener...</font color=blue>
Ah... ha... you thought you had me... /w3tcompact/icons/laugh.gif
I'll look up the max "torque" on the blade bolts later... believe it's somewhere around 1000-1200 ft. lbs. or greater .../w3tcompact/icons/wink.gif
/ ford 1700
Thanks for the many photos, they have been a great help.
The only differences I have noticed, is the alternator is slightly different.. but then... I've changed out alternators on tractors with non oems before too.
The other difference is the valve cover. ( head and block are identical ) The valve cover on the one I'm looking at is kinda rounded ( looking something like the top of a milk jug, with the fill cap centered. Non oem replacement? This might be the evidence that this is a ford look alike or a similar production run from someone like shibarua <sp?>
Again, thanks for the work on the photos!
Soundguy
/ ford 1700
The 1920 and the 2120 are almost identical to look at. I love my 1920, good and strong. I lucked up on mine while at the dealer to buy a new tc18.. wasn't reallt big enough for what I wanted.. but I had a budget of 10k. So while I'm looking, I see this 1920 parked behind it. Turns out, it was gone over, and had an engine rebuild there at the dealer. Had 2 hours on the engine, and 720 on the meter. The had it for 9500. I got them to put a sun shade on it and make it a deal. I am very happy with it. I do a bit of boxblading, pasture dragging, move some dirt with the rear scoop, and move round bales with the 3pt bale spear... some seed/fertalize and mowing and discing.
Good and strong.. nice weight too.. 3300 or so. Mine is the 4x12 gear tranny, which I happen to like... I don't really prefer hst.
As for cons... I guess it needs a rear work light.
While I don't have any remotes or other hyd. taps, it does come standard with the hyd manifold on the lower right side to make hyd connections too... that is standard on most of the nh stuff I think though.
Since you took the time to get me some pictures, When I go bush hogging this afternoon, I'll try to remember to take the digital camera with me.
Soundguy
/ ford 1700 #31
Great! Everyone around me has Orange tractors, friend and family alike. In looking at the dealer who handled both NH & Kubota, I found the older Ford series to be much greater value. You got a good deal on that 1920 - I looked at one with a bucket that was tired for $11k. As I've been over to the local NH dealer for parts, I've had a chance to eyeball the new Boomers - pretty nice. Wonder how they compare to the Kubotas.......
Thanks for getting pics ahead of time - and what are you going to do with the 1700?
John - are you talking inch pounds? Seems a little low if you are - 1200 in-lb would be 100 ft-lb. Or is it Newton-meters? /w3tcompact/icons/tongue.gif
/ ford 1700 #32
Re: ford 1700 & Mini Quiz...?
<font color=blue>…on mine I always had them about 500-600 ft.lbs…</font color=blue>
Foot…ft… as in Boot… /w3tcompact/icons/grin.gif
or if you prefer …~~680-820 newton meters…/w3tcompact/icons/wink.gif
On my current Brown rotary cutter, the blade bolts are torqued to about 800-900 ft. lbs.
...and on the Brown tree cutters… the blade bolts are 1400-1600 ft. lbs… and the stump jumper or blade bar is torqued to 3800 ft. lbs… /w3tcompact/icons/shocked.gif
Let me ask you guys a question... How much torque can the PTO splined steel shaft handle? (not the rest of the PTO components... just the steel shaft)
Answer tomorrow... /w3tcompact/icons/smile.gif
/ ford 1700
Ok, here are the start of the pictures. This one is the left side of the 1920... still on the trailer from bushhogging the neighbors pasture. I hadn't washed if off before I took the pictures. Also, the top riser on the smoke stack is not oem. It came with the usual straight pipe with an angle to the side. I added the slightly taller pipe with a flapper cap. It keeps the fumes outta the face better... though... I must admit, I'm quite fond of deisel fumes.../w3tcompact/icons/smile.gif
( I will probably not buy the 1700, as the 'dealer' seems odd.. I can't put my finger on it.. but there is something just... odd about the guy .. though the tractor does look nice. )
/ ford 1700
rear of the 1920, minus the mower, as I left it at the neighbors.
/ ford 1700
right side
/ ford 1700
And one of my favorite parts, the fender mounted radio. I should have taken a lower angle, and got the cup holder in there too. This picture isn't as clear, but should be ok.
/ ford 1700 #37
Depends on shaft size, and on whether you're talking about spline failure or the actual yield point of a shaft of the size that we're talking about - if you mean the point at which the whole shaft would fail - tons. If you mean the safe working limit - much less. I don't have time to drag out references and re-learn how to calculate yield point from torsional loading, although you are getting me interested in it, again.
I believe the torque specs for bolts are based on a specific bolt material, desired clamping force, the resulting tension in psi, and allowable deformation or bolt stretch - which is why the specs for stronger (grade 8) bolts are higher. I always understood that the idea was to apply a certain clamping force - the only way we can reasonably measure that outside a lab is to measure the stretch in the bolt, or derive specs/tables to relate it to the nut torque. Not knowing what size bolts I have on the cutter, but assuming they are in the area of 1", I would guess the torque would be in the hundreds of lb-ft, as my experience with cylinder head bolts and wheel lugs (1/2" bolts plus or minus a 1/16" here and there) is in the 75 - 90 lb-ft range.
I was just Bill Nye-in' around with the Newtons - I think we should throw all the metric bolts in Boston Harbor. Sure, it's easier to calc in base ten, but I like our old way of doing things. Heck, I like cubits, rods, and furlongs. My longtime favorite unit of measure is Furlongs per Fortnight, first spoken by an instructor as a joke. If speedometers were marked that way, 60 MPH would be 161,280 FPF /w3tcompact/icons/grin.gif.
/ ford 1700 #38
Nice pictures, Chris! That's one rugged tractor. My stack is a bit low - I think I'll extend it, too.
I always figured you had to use headphones with a radio on the tractor. I could have used one while I was cutting grass the other day. And a sun shade.
What kind of camera do you have? This thread is going all over the place, as usual. I borrow the Kodak from work when I need it. I like it, but it's $4-500.
/ ford 1700
<font color=blue>Nice pictures, Chris! That's one rugged tractor. My stack is a bit low - I think I'll extend it, too.
<font color=black>Thanks, they could have been better, but I used a lower res to save upload size, and I was tired from bushhogging so I didn't get the best angles. Both the smoke stack on my yanmar and the 1920 were too low for me, so I went to autozone, and bought the appropriate muffler tube size, used a chop saw to cut the bottom of the stack to have 4 'leafs', then a muffler clamp to hold it on. The flapper I got at TSC. Just a tad bit of rattle when it runs.. but not bad.. keeps the rain out too.
<font color=blue>I always figured you had to use headphones with a radio on the tractor. I could have used one while I was cutting grass the other day. And a sun shade.
The sun shade is great.. blocks a bit of rain as well. The radio will either play through an internally mounted weatherproof speaker, or via headphones... funny thing is, is the internal speaker is mono-mixed, and the headphone is true stereo.. more than i would have expected.
[blue[What kind of camera do you have? This thread is going all over the place, as usual. I borrow the Kodak from work when I need it. I like it, but it's $4-500.
<font color=black>It is a polaroid pdc 640. I still think they sell it or a similar model. When we bought it, it was 299.00 and had a 2mb smartmedia card with it ( smartmedia are the thin real thin ones ). 2mb holds about 15 pictures in hi res. The extra 8mb card we bought cost 64 bucks ( this was all in 1999 ). Nowadays, the camera is probably less than a hundred bucks, and smartmedia is really cheap.
Good camera. A suggestion, if you get one, either smartmedia or compact flash, do yourself a favor and buy a seperate usb based reader for the media, unless the camera has a built in usb interface. Most cameras I've seen make you hook them up to the serial or printer port of the computer, and only a few are usb capable... takes forever to download the pics, and their software is sometimes slow. I bought a usb reader that accepts the smartmedia, and makes it like a drive on your desktop.. just drop and drag the pics in jpg format over to your cpu.. the readers are cheap too.. like 25 bucks.. end even places like eckards carries them in the camera dept.
Soundguy
/ ford 1700 #40
Hey Chris
Been plating around outside for a couple days. The Kodak at work has a usb cable - once I got the software loaded (which it basically did itself), we just plugged the camera into AC power, plugged the usb cable into the front of the PC, turned the camera on, and it did everything else. I think the camera is a model 4000 or 4400 or something. It's so "plug n' play", that all I had to do was read the manual to make sure I could decipher the markings on the camera controls. I'm still learning about resolution and so forth, mostly by reading the help text on the Adobe program included in this PC. It seems there is a difference between what Adobe tells me the file size is, and the saved JPEG file (saved file smaller, thank God). I've been stumped by not being able to get the file size under 150k, only to find out the saved image was well under. So far, I'm happy to be a user only, and get by.
Do you have a manual that shows blade bolt torque, Chris? Been waiting for John to get back to us on bolt torque, too - HEY JOHN! /w3tcompact/icons/grin.gif Since I don't have a manual, it'd be nice to know.
See Ya
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2022 EZ-GO ELITE...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
