Ford 1700 starting problems
/ Ford 1700 starting problems
Before I bought parts I would isolate the problem. I would disconnect everything from the starter, clean and replace only the battery leads. Check the battery connections and the ground connection. I would then use a jumper/screwdriver to check starter operation. If it doesn't turn over you still have a battery/grounding/starter problem. If the starter works move to the next item.
Russell
Russell,
I've done all that. When doing the screw driver part the starter spins, but the fan/engine only moves a few inches. I'd like to not waste money on parts also, but if the repair people say the existing is bad, I don't think it will be a waste? I'm not extremely mechanical, but I'm willing to learn and try suggestions. I appreciate the input!
Jason
/ Ford 1700 starting problems #22
Cj, if he tractor does not crank properly with the key off and using screwdriver or remote switch then you have a battery or cable/connections or starter problem. What is the battery voltage during cranking. How are the cable connections and grounds?
OK, I've replaced the battery connectors and cleaned the ground off the battery. The battery itself is new, but I know that doesn't mean much sometimes. I'll have to check the battery voltage at cranking the next time I'm there. I plan to look for and clean other grounds the next time as well. I got a wiring schematic, so it should help me locate them. Thx!
/ Ford 1700 starting problems #24
There is only 1 ground. Follow the neg battery cable to where ever it bolts to the frame/engine block.
/ Ford 1700 starting problems #25
As I recall, the negative on mine bolted to the battery tray, which bolts to the frame. The battery tray to frame bolts were rusty and corroded which caused issues. When I replaced the cable (and bolts) I picked up an extra negative to run from the battery tray to the frame. Haven't had any problems since.
Your right about the tray & mine is pretty bad. That was on my list to replace when I get the thing running. The extra strap couldn't hurt. I did hook jumper cables up to the negative post and a spot on the frame at one point, but it might not have had good frame contact. Thanks!
For an update, I got the alt and key switch in and installed. I installed the alt first and got the same result as before, but the alt wasn't getting super hot anymore. Then I went to install the switch. I pulled the fuel tank, which was mentioned in another post, to get access to the backside of the instrument panel. I also removed a support member for the panel. After noting all the connections, I swapped the switch, and that did the trick. The switch was shorting I guess. I don't have the tractor running yet, but it is turning over now. I need to purge the fuel system and I'm hoping that will get it running. Thanks for everyone's help.
Additional update. I got the fuel system purged and the tractor running. I was real excited as this was a big accomplishment for me and my limited skills/experience. Again thanks to everyone for the help. I went ahead and shredded with it for a hour to heat things up and changed the oil, oil filter, and added the fuel filter (prior owner had ran without one). It does have a lot of mostly white smoke on start up for 5 or six minute and the power lift drops right away when the engine is killed. I know someone had a post on here about a seal or o ring that was originally plastic and been replaced by a rubber one that fixed that issue. Anyone have a link to that?
Update... Been using the tractor to shred a few times the last couple of weeks and it's been running good. In between shredding, I changed the hydraulic fluid, cleaned out the metal strainer, replaced the o-rings on the hydraulic lines, cleaned the air cleaner out, replaced the oil in the air cleaner, drained the oil in the injector pump and replaced the oil. The steering is fairly sloppy and I've found out the pervious owners broke something in the steering that was welded back instead of replaced. More importantly, I went to fuel up with ag/red diesel after a shredding session and now the tractor won't start. Prior to this tank, the tractor had only ever been ran on normal road diesel. If I put the throttle at half throttle, like I normally do to start, it just turns over like it normally would to start, but never quite gets running. I tried to start it on full throttle and the cranking seems to be happening slower at full throttle. Over a few hours, I tried it several more times, but got the same results. I purged the fuel lines and injector pump and the red fuel flowed out as expected. I've always used Power Service Diesel Kleen +Cetane Boost and have done so in this tractor also. Anyone ever had issues going from road to red diesel? my understanding is that the only different is the dye. Please understand I'm not trying to start a debate on the quality of various fuels.
/ Ford 1700 starting problems #32
I'm perplexed as both are the same with difference being dye. Saying that I never bought red dyed diesel for ag. At work, we have 3 ,10000 gallon tanks and we always use non-road type diesel and also use it on several vehicles that have diesel engine and never had an issue. I do use the same power service product for my old Ford and have had no issues. Will see what others think of this problem. Why don't you save the red diesel in a tank and buy some road type and see you end up where yu left off.
JC,
JC,
JC,
I use fuel from the same barrel on my IH 886 and Power Service as well. Just seems like I read somewhere of a person having an issue of switch from road grade fuel to dyed diesel, but I'm not sure it made much more sense than my situation. If' I don't get any other suggestions, I do plan to drain the fuel and try again with road diesel. Good thing this tank is only 5 gallons and not the 50that is in the 886!
/ Ford 1700 starting problems #34
Does it normally start right up or do you have to use the glow plugs? I think I've mentioned in another thread that when I got my 1700 home after a 4 hour trailer trip, it would not start for nothing. It ended up being the thumb screws on the glow plugs (they came loose during the trip). Something easy to check anyway if the plugs are the norm and it's been bounced around out in the field.
-Neil
/ Ford 1700 starting problems #35
I thinking that when you changed oil in the injector pump, something went wrong. I believe messin' with red diesel is not gonna solve your problem. Since the tractor was running so well before, you have to look at the one thing you did that had something to do with the fuel system. I believe recently somebody else had problems after changing injector oil. JC, can you jog my memory? Didn't you help somebody with a similar problem? Was it Pete Clausen?
Yep! Found it here.
/ Ford 1700 starting problems #36
You are right Mr. Jim , good memory:thumbsup:
Cj, did your fuel injector pump have drain and level hole? Did you open the back plate of the pump? how did you change oil and how much did you put in? how much old oil did you dump out?
JC,
It has all the holes specified in the book: drain, level, and fill. I didn't have to open the back plate. I put in oil like the book said, until it runs out of the level plug. I didn't have a measuring cup to put in the amount you suggested. As far as how much came out, if I had to guess about two ounces. It was real dirty black. It ran fine for at least an hour in the field with regular street diesel after servicing the injector. When the tractor is cold, I do have to use the glow plugs. I will check the glow plug thumb screws and try it. If that doesn't help, I'm going to draining the red diesel and swap it back to street to see. I plan to give the tank a good cleaning also. I haven't searched the forums yet, but do you have any recommendations on interior, metal tank cleanup? I've been meaning to get some pictures also, but I keep forgetting to bring my camera.
Thanks to all that responded.
/ Ford 1700 starting problems #38
CJ,
Go ahead and remove the rubber fuel house from tank after you shut the tank valve off. Out a cup under the hose and open up the valve. I'm going to make a wild guess that you have a very low flow or no flow at all. Same thing happened to me and it was a piece of rubber coming off of fuel tank cap. I ended up blow some air from the hose end in to tank to open it up. When I tried to clean my tank. took a round brass brush form HF . the ones you put on dril. You want something non-sparking, steel will cause spark. That is very important with gas but as important with diesel. I got a long 1/4 dia rod and welded the brush to the rod. My plan was to drive the brush/shaft with a drill. I emptied my tank. and realized I had no rust at all, so I kept about 1 cup of diesel in there and brush it some to get dome sediment out, sloshed it around and dumped. Used clean diesel and repeated the procedure couple of time and each time used just 1 cup or so of diesel. keep teh contaminated diesel to use it when you have burn.
JC,
PS. You did everything right for changing the oil from your description. Can't see any cause you could have done specially no opening the back plate. Pete had no drain hole and had to open the back plate.
/ Ford 1700 starting problems #39
it sounds like the off road diesel is coincidental to the actual problem. is there a way to flush out the fuel pump? when you drained and refilled some tiny piece of debris may have become dislodged. i'm guessing that you are the only one whose done any maintenance on this thing in a long time.
of course the diesel could be contaminated but then you wouldn't be the only one with problems using it. has the place you got it from had any complaints about it?
CJ,
JC,
JC,
I'm going out to the farm this evening and hope to check the fuel flow and glow plug thumb screws. Don't have a H.F. in town, but will at least empty the last little bit of fuel for burning just in case. Someone else had posted a while back about there being something above the valve inside the tank. I'm thinking about taking the valve loose and making sure everything is good with that.
Randy,
I think the diesel is good as I use it from the same barrel in another tractor. This tractor sat for two years at the place I got it from and I doubt they serviced the injector pump.
Thanks for all help!
2016 Ford Explorer (A61574)
2016 Ford Explorer...
Caterpillar Tech Manuals (A63117)
Caterpillar Tech...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A61572)
2018 Caterpillar...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
