Ford 1700, introduction, part deux
   / Ford 1700, introduction, part deux #21
It's almost like there needs to be a Ford Shibaura forum. I realize my 1100 is quite a bit smaller than the 1700, but the machines are so similar (1100, 1200, 1300, 1500, 1700) that Ford saw fit to put them all in the same service manual. I bought this thing new in 83 and it now has over 4000, very hard hours on it. The first 25 years was kept out in the rain, but after repainting and putting on new decals she's earned a spot in the garage. Water pump, hoses, starter, thermostat, head gasket, lift seal, PTO seal, sediment bowl, muffler, oil pressure sender, tires, batteries, fuel injectors, and of course fluids and filters. Not bad for 32 years.
Fawken:
I have a mechanical oil pressure gauge on my 1700 as the sender went bad. Do you have a source for an original so I can get the 'idiot' light to work again? I'd actually probably 'y' that oil pressure port and put a sensor AND mechanical gauge on (I like numbers when it comes to important things like oil pressure). Speaking of oil pressure, what is 'good' oil pressure for a 1700? At operating temperature, mine is around 35psi at a 800rpm idle and around 50psi at 2500. Seems plenty for only 2500rpm, but wonder if there is a range for 'normal.'
Brian A.
1979 Ford 1700 2wd
   / Ford 1700, introduction, part deux #23
Fawken:
Actually, I got that sender unit about this time last year direct from NH. Pricey, but they can get them. I was tilling about a 1/2 acre and the oil light started blinking. That's a scary feeling since the tiller puts more strain on my machine than anything including the backhoe. The service manual is at the shop, but those pressure numbers sound low to me. I'll look it up.
   / Ford 1700, introduction, part deux #24
Well, darn it. I guess Ford (or I&T) didn't think oil pressure data was too important. No specs given for any model. They do say that all models have an oil pressure relief valve that can be adjusted. I would warm the engine good, pull the valve cover and observe oil flow to the top-end at idle. Should be a nice steady dribble (not spurting) out of each push rod.
Fawken:
Do you have a Ford part number for the oil pressure sending unit? I searched the NH parts store with little luck. I found a used one at Wenger's for ten bucks, but that's just running on borrowed time, IMHO.
Brian A.
1979 Ford 1700 2wd
   / Ford 1700, introduction, part deux #26
http://www.ebay.com/itm/FORD-Shibau...46010-SBA185246011-SBA185246050-/250931675119
$18.95 which is about half what I paid at NH a year ago. It looks the same, BTW. I assume you are going to the official New Holland parts look-up site Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
which is where you start and you can get the part # there (SBA #) every time. Apparently, oil pressure senders are no longer on the agenda at New Holland as they don't show a price. Welcome to the world of Shibaura Fords. Use that part number and just paste it into your browser. You'll find the part, I promise. These tractors are some of the most durable ever built and Shibaura marketed those engines to a variety of equip mfrs world-wide. The oil pressure sender is one of those parts that cross-references to a ton of engines. The one on E-Bay seems reasonable to me.
Fawken:
That is the NH website I was perusing indeed, but I obviously don't know how to search as I still can't locate the number! Ha! The oil pressure sender you listed from eBay certainly is reasonable, but the connector doesn't look right to me (understand I don't have the original unit, only the wire that goes to it). It looks to me that the connector end on my tractor (a 'c clip' where you tighten a screw around it to secure) wouldn't work on this unit. Obviously snipping the wire off a bit and putting on a new connector is no issue, just wanted to make sure that my original wiring harness hadn't been tampered with in the past (doesn't appear to have been). If this eBay unit is the cross referenced part for the 1700, it sounds like I don't have much of a choice but to change the wire connector. Given my obvious inability to search the NH parts website correctly ( ;) ), which of the three part numbers listed on the eBay ad is the correct one for the 1700? Given the price of a new one at $18.95 vs. $10 for an old one from Wengers that will undoubtedly fail in the (near) future, the choice seems clear.
Brian A.
1979 Ford 1700 2wd
   / Ford 1700, introduction, part deux #28
What I found over the years, Brian, is that Ford often had different part numbers for an identical part. i.e. this sender probably works on all the 1000 series Shibauras, but Ford gave a different part number to each. Did you try searching the NH web site for a 1500 sender? The other question is have you called your NH dealer directly? I know for a fact I bought that sender at NH so maybe I just called the dealer- can't remember.
   / Ford 1700, introduction, part deux #29
Fawken:
Brian A.
1979 Ford 1700 2wd
ZR WON, I have the part number for the original equipment.
Part #SBA185246011 sender unit. Original unit has a screw terminal on the end to use a wire with a round connector(or C clip).
This is a place on the west coast that has practally every part for Ford/Newholland parts.
Brim Tractor BRIM EQUIPMENT
Part is listed under engine parts: #12 Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
They may have everything you would need for your 1700.
I ordered 1 in 09/2008 and it cost then $20.79
At the same time I ordered a seal for my 3 point lift for $11.98
   / Ford 1700, introduction, part deux #30
I paid $39 for the sender last year at NH and about $30 three years ago for the lift seal also at NH. Inflation? Or were they sending a message that they really do not want to stock parts for these machines? Also, check these guys out if you need something major: Southern Global
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
