Ford 1700 Hydraulic question
   / Ford 1700 Hydraulic question #1
mcarroll
ford
My Ford 1700 is equipped with remote port but will only operate when the 3 point is raised. I need to be able to operate the 3 point and the remote separately. I have debated between installing a pto pump and reservoir or an interrupt of the high pressure hydraulic line to supply the remote valve. After searching here and elsewhere, the interrupt using compression style fittings seems the easiest way to go. My question is, can anyone tell me what the id of the high pressure hydraulic line is? The od is 5/8 but before I cut the line I want to have the appropriate size fitting so the flow to the valve and the return to the high pressure line is not changed.
   / Ford 1700 Hydraulic question #2
I will be watching for a response.
I have a similar issue on my Ford 1920.
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
