Ford 1700 Hydraulic question
/ Ford 1700 Hydraulic question #1
mcarroll
ford
My Ford 1700 is equipped with remote port but will only operate when the 3 point is raised. I need to be able to operate the 3 point and the remote separately. I have debated between installing a pto pump and reservoir or an interrupt of the high pressure hydraulic line to supply the remote valve. After searching here and elsewhere, the interrupt using compression style fittings seems the easiest way to go. My question is, can anyone tell me what the id of the high pressure hydraulic line is? The od is 5/8 but before I cut the line I want to have the appropriate size fitting so the flow to the valve and the return to the high pressure line is not changed.
/ Ford 1700 Hydraulic question #2
I will be watching for a response.
I have a similar issue on my Ford 1920.
2024 Chevrolet Camaro Coupe (A66738)
2024 Chevrolet...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
THERM DYNAMICS TD 375 FLAMELESS HEATER (INOPERABLE) (A68842)
THERM DYNAMICS TD...
