Ford 1700 Hydraulic question
   / Ford 1700 Hydraulic question #1
mcarroll
ford
My Ford 1700 is equipped with remote port but will only operate when the 3 point is raised. I need to be able to operate the 3 point and the remote separately. I have debated between installing a pto pump and reservoir or an interrupt of the high pressure hydraulic line to supply the remote valve. After searching here and elsewhere, the interrupt using compression style fittings seems the easiest way to go. My question is, can anyone tell me what the id of the high pressure hydraulic line is? The od is 5/8 but before I cut the line I want to have the appropriate size fitting so the flow to the valve and the return to the high pressure line is not changed.
   / Ford 1700 Hydraulic question #2
I will be watching for a response.
I have a similar issue on my Ford 1920.
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
2014 FORD F150 4X4 CREW CAB PICKUP TRUCK (A52576)
2014 FORD F150 4X4...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
