hgd1956
I have a 1979 Ford 1700. I bought it as a basket case and it have proven to be a real challenge getting in running shape. I managed to get it all together only to find that the hydraulic pump is very weak. No real pressure and the flow is low as well. When I bought the tractor it had been sitting for about 6 years apparrently outside. I have pulled the pump and disassembled it only to find that it has been damaged internally and needs to be replaced or repaired. This is the problem, New Holland has a new pump, 845 dollars or a rebuild kit that only addresses the seals and such, no internal parts. Also, it appears that the early 1700s had a bigger pump than the later models. I ordered a used pump from LCI and of course it was the smaller later model. Help Please...........................this thing is killing me!
