Ford 1700 glow plug
   / Ford 1700 glow plug
Indicator works, when l put new plugs into works great but you can tell after about 3 uses it really slow lighting up and when the plugs are toast it doesn't light up at all
   / Ford 1700 glow plug #12
When you turn the key right to start I wonder if the glow plugs are getting to much juice and burning out. If you hooked a light to the glow plugs it would show when they or on and how long
   / Ford 1700 glow plug #13
glow plug review on amazo* Garbage.... lasted 2 startups and Then burnt out. idk junk plugs.....:confused3:
I wondered that myself but l found some NGKs and the same thing happened.
   / Ford 1700 glow plug #15
I found a picture of the back of the key switch # 19 glow plug resister # 17 glow plug resister and glow plugs
I think that is my next ste, changed the indicator, plugs, there is no safety switch. Thanks for your research l'd buy you a beer if l could
   / Ford 1700 glow plug #19
Let me know how you make out with the new parts..
   / Ford 1700 glow plug #20
I think the problem is at the injection/compression/combustion processes, see this information (page 6):
https://www.boschautoparts.com/documents/101512/0/0/0b189154-b815-46d7-bf70-e153bb6ecb88
At over-voltage you get a swelling/melting from the inside out (or no visible damage). The damages on your plugs seem very much to come from cold diesel fuel sprayed over the hot tip of the "bulb", causing it to crack, when the engine is running.
Do not buy anything yet, apart from plugs.
Check the timing and the injectors, before you put the new plugs in.
And look for/clean out parts from the damaged plugs inside the cylinder.
I found a wiring diagram at New Holland Online Parts List during my research. I thought it may be of use, maybe not for this problem but it is always nice to have:
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
3pt Ditcher (A57149)
UNUSED WILD BOAR AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED WILD BOAR...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
