Ford 1700 battery replacement
/ Ford 1700 battery replacement #1
geozeitl
Green bay wi
Ford 1700
I bought my ford 1700 last year. I'm starting to think the battery is undersized. Its the size of a car battery but the battery stand is way bigger. Seems when l use the glow plugs at first it weakens the battery were it doesn't crank very fast. Does anyone have an idea of what size battery l should buy? My service manual gives me a part number but of course it's not made anymore with no info. Any ideas?
/ Ford 1700 battery replacement #2
I would think that any good battery store should be able to cross reference your part # with a currently produced battery. What is even better - from the part # - - get the Group #. Then you can buy a battery of the same size or get a bigger one that will fit in the battery stand.
/ Ford 1700 battery replacement #3
The current New Holland part number for a replacement battery is F165DSW which is a BCI Group24 battery. They are available anywhere batteries are sold and come in a few different CCA ratings.
Hey, thank you both for your advice will check it out
/ Ford 1700 battery replacement #5
Get the largest battery that will fit in the battery holder, and has the the most cold cranking amps.
Best bang for the buck is the Everstart Maxx from Walmart.
/ Ford 1700 battery replacement #6
I have also had really good luck with Wal-Mart battery and Exide
too.
Hey thanks for the advice, will check it out
/ Ford 1700 battery replacement #8
totally agree the most CCA you can fit will do the trick, although the everstart might not have the greatest longevity they are cheap !
Thanks just bought one and what a difference
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
Brillion Cultimulcher (A66408)
Brillion...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
