Ford 1700 3 pt problem
/ Ford 1700 3 pt problem #1
wonl2
Taylors
Ford 1700
Greetings JC, I have a Ford 1700. The tractor has 560 hours and has been sitting for the past 10 years. I bought it at an estate auction. The hydraulics worked very sporadically. I drained the hydraulic oil twice, cleaned the screen twice, vacuumed inside the opening where the screen is located. I replaced the lift cylinder seal, and cleaned the relief valve. I also opened up the pump and everything looked great. I also cleaned up the control valve. I replaced all o-rings as I worked through the system.
After all this work the 3 point doesn't work at all. I opened up the banjo bolts at the pump and hydraulic fluid was present. I spewed alot at the pressure side. I also loosened the pressure banjo bolt at the relief valve and pressurized hydraulic fluid spewed out. I attached a pressure gauge on the left side of the cylinder head, there was no pressure.
When I screwed in and out the bolt to the relief valve, there was a noticeable sound change coming from the hydraulic pump.
Do you have any ideas on what is wrong with my hydraulic system? Any feedback will be greatly appreciated. Thanks for your assistance.
Phil
/ Ford 1700 3 pt problem #2
Check to see that the 3-point lowering speed knob is wide open. Twist it all the way in/out several times. This adjustment could be full of old oil & gunk. It should be on the "shelf" directly below the front lip of the seat and very near the floor.
I removed the piston cylinder assembly where the speed knob is located. Replaced the piston seal and cleaned everything.
I think I resolved my problem....so far. I neglected to say that the tractor also has a FEL. I disconnected the lines to the FEL because I am rebuilding the FEL. I had the lift cylinders rebuilt, replacing all lines and fixing surface rust. The 3 point didn't work after I removed the FEL lines. Come to find out the FEL control has an open center which circulates hydraulic fluid through the FEL control.
Once I installed a line connecting the output and input to the FEL the 3 point operated smoothly. One problem I found was that after driving the tractor for about 10 minutes the 3 point didn't work again. I backed out the relief valve until fluid came out and the 3 point started working again. Any Ideas why this happens???
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2022 CHEVROLET...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
