Ford 1520 front wheel/axle leaking
/ Ford 1520 front wheel/axle leaking #1
jwalk2c
Claremont NC
Ford 1520- 1987, Deere Track Loader 455G- 1997, Wheel horse C160 x 3 , 418-8 , 314-8
Hello,
I have a 1987 Ford 1520 that's developed a leak at the right wheel on the inside.
I have not pulled the wheel off to check on it I am hoping it could be a seal.
Does anyone know if there is a wheel seal in there?
I have a front-end loader that I installed and it has not been abused but the loader does put a lot of weight on the axle and I am concerned about that.
Thank you
John Walker
/ Ford 1520 front wheel/axle leaking #3
Possibly related, I replaced both bad tie rod ends (your #42 on diagram) on my NH1920 because I noticed a lot of 'play' translated to the arms on top of the wheel assemblies of the front axle. The oil leak that I was having from the wheel assembly has almost stopped since replacing the tie rod ends.
Thank you for the parts diagram!
John
TANK MANIFOLD (A55745)
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
WATER TRAILER (A58214)
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
Light tower (A60352)
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
