ford 1320 hydraulic issue
/ ford 1320 hydraulic issue #1
israelrt
Ford1320
Hello everyone, I have a 1989 Ford 1320 tractor with a manual transmission, and I’m having a problem. I have more or less the skills of a mechanic, and I bought the tractor’s workshop manual, but I don’t really know where to start.
I have an intermittent hydraulic problem that’s getting worse. I can use the tractor and operate the front loader or rear implements, and it works perfectly fine for several hours. Sometimes, there’s a small hesitation when lifting the loader, but nothing more.
However, as soon as I stop the tractor and restart it, I lose all hydraulics nothing works at the front or back — and this can last for a long time. Sometimes, if I push the throttle all the way up, the hydraulics suddenly come back, though I don’t know if that’s just a coincidence.
I really need some help. I’m not sure if any of you might have an idea of what it could be. The problem is intermittent. I’ve already changed the oil and the filter, but it didn’t solve anything.
Thanks a lot
/ ford 1320 hydraulic issue #2
Welcome to TBN!
You are losing prime on the pump. Look at the suction line to the pump for a loose clamp on a flexible hose connection.
Could also have a loose joint on the suction line.
Welcome to TBN!
alright thanks a lot I'm gonna check this out , people also says to check the strainer, do you have any informations about it ? the localisation ?
/ ford 1320 hydraulic issue #4
There is no strainer on a 1320, just the spin on filter
500 GALLON STEEL FUEL TANK (A60430)
500 GALLON STEEL...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
UNUSED IRANCH 20CM TOOTHBED MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 20CM...
Rooster Weathervane (A55853)
Rooster...
UNUSED SDLANCH SDLD25 MOBILE HYD DUMPER (A60430)
UNUSED SDLANCH...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
