Ford 1310 - where is reverse?
   / Ford 1310 - where is reverse? #1
Sunsetkitten2783
Ford 1310
It痴 rather embarrassing but I can稚 figure out how to shift my Ford 1310 tractor in to reverse. I even purchased the operators manual but it doesn稚 specify how to shift it into reverse either. I have the main shifter on the steering column and the gear shift diagram only shows 1-4. I致e tried every combination of the main shifter and the gear shift but nothing seems to work.
   / Ford 1310 - where is reverse? #2
I'm not familiar with that tractor but found this on Google. Does it make any sense?
Yep, that doesn’t match mine. It only has the four gears 1-4
   / Ford 1310 - where is reverse? #4
If tractor data is correct it has 12 forward speeds and 4 reverse
so a 4 speed main and a Hi, Mid, Low and reverse aux transmission
   / Ford 1310 - where is reverse? #5
Lever on the left hand side of the steering column, forward is up, reverse is down toward you.
That doesn’t seem to work so there must be something wrong with the main shifter.
   / Ford 1310 - where is reverse? #7
Lift the "main shifter" up and pull down.
That is reverse.
Down down is 3rd gear forward.
down up is 1st, up up is 2nd.
OR if easier to understand,
Down/forward is 1st gear forward.
Up/forward is 2nd.
Down/back is 3rd.
Up/back is reverse.
The 4 speed is a range shifter, the higher the number, the faster the ground speed.
   / Ford 1310 - where is reverse? #8
That is reverse.
Up/forward is 2nd.
Down/back is 3rd.
Up/back is reverse.
That sounds like an old 3 on the tree or column mounted 3sp shifter for pickups and cars.
   / Ford 1310 - where is reverse? #9
Just remembered a problem I had.
As in your case, shifter didn't respond.
Problem was a roll pin in the linkage came out.
   / Ford 1310 - where is reverse? #10
Same idea just different pattern.
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2018 Toro Sand Pro Bunker Rake (A49461)
2018 Toro Sand Pro...
