Ford 1300 injector pump
   / Ford 1300 injector pump #1
Cornskillet
Burns! Tn
Ford 1300; kubota l3800
My Ford 1300 die as I was starting the PTO and the transmission. Now the injector pump is not pumping fuel to the injectors. Is there a way to test the pump before paying $$ for a rebuild?
   / Ford 1300 injector pump #2
Did you get this solved? Did you rum out of fuel or have trash blockage? Start at the fuel tank and check for fuel flow. Work your way down to the filter and finally the injector pump. If you have good gravity fuel flow the next step is loosen the lines at the injector and crank the engine over, looking for fuel at the loosened fittings. Be careful not to overheat the starter.
   / Ford 1300 injector pump #3
ditto.. check fuel delivery TO pump first..
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
