Ford 1220 questions
   / Ford 1220 questions #1
silverbk
Hello group,
I have a Ford 1220 compact tractor. I am relatively new to this machine, having only owned a lawn tractors before this.
I want to buy a 715a snowblower for the front. I found one at a tractor dealer in Iowa. I was hoping to get a head start on getting the tractor ready to run this implement while we are sorting out the freight.
I understand I need a front hydraulic remote. Do I also need a valve? Or is the valve mounted on the implement like a bush hog loader?
Are these parts still available from New Holland? I was told that Bush Hog makes what I need. Can anyone advise further what I need to buy and install. I would also like to add a rear remote so I can have a dumping trailer, Ideally they could all be installed at the same time.
Thanks in advance.
   / Ford 1220 questions #2
I run front hydraulics on my TN. They are just hoses run from the rear hydraulic ports.
Andy
   / Ford 1220 questions #3
As Andy said.. if you have a rear remote.. you can just plumb it forward.
if your snowblower needs more valve function than the DA remote.. then it will need a compatible valve.. find out if it can use the da remote.. or if it comes with it's own valve.
if you don't have a remote.. price one.. last time I did at cnh they were going for about 700$!!
Soundguy
2014 Audi A4 Sedan (A48082)
2014 Audi A4 Sedan...
2015 Buick LaCrosse Sedan (A48082)
2015 Buick...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2018 Ford F-150 (A50397)
2018 Ford F-150...
2015 Nissan Pathfinder AWD SUV (A48082)
2015 Nissan...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
