Ford 1220 questions
   / Ford 1220 questions #1
silverbk
Hello group,
I have a Ford 1220 compact tractor. I am relatively new to this machine, having only owned a lawn tractors before this.
I want to buy a 715a snowblower for the front. I found one at a tractor dealer in Iowa. I was hoping to get a head start on getting the tractor ready to run this implement while we are sorting out the freight.
I understand I need a front hydraulic remote. Do I also need a valve? Or is the valve mounted on the implement like a bush hog loader?
Are these parts still available from New Holland? I was told that Bush Hog makes what I need. Can anyone advise further what I need to buy and install. I would also like to add a rear remote so I can have a dumping trailer, Ideally they could all be installed at the same time.
Thanks in advance.
   / Ford 1220 questions #2
I run front hydraulics on my TN. They are just hoses run from the rear hydraulic ports.
Andy
   / Ford 1220 questions #3
As Andy said.. if you have a rear remote.. you can just plumb it forward.
if your snowblower needs more valve function than the DA remote.. then it will need a compatible valve.. find out if it can use the da remote.. or if it comes with it's own valve.
if you don't have a remote.. price one.. last time I did at cnh they were going for about 700$!!
Soundguy
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2014 Ford Escape S SUV (A48082)
2014 Ford Escape S...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
