Ford 1210
/ Ford 1210 #1
Schoochie
Ford
Just bought a Ford 1210-it’s leaking oil around the injectors-what would be the best fix for this-thank y’all
/ Ford 1210
Thank you Harry-that’s what i thought also-but i got it in the sunshine today and when the tractor is running it’s leaking oil around the injectors-is there supposed to be a gasket around the injectors
/ Ford 1210 #4
it is most likely diesel fuel that is less volatile and more oil like as it dries out.
/ Ford 1210
Thank you JC -can I stop this from happening
/ Ford 1210
I don't know why there would be oil "around the injectors" unless it's getting past the valve cover gasket.
I
Is there anywhere i can get a valve cover gasket for a 1210-I’ve searched but no luck-maybe silicone would work
/ Ford 1210
Is there a place i can get a 1210 valve cover gasket or just use silicone
/ Ford 1210 #8
It is difficult or expensive to source valve cover gasket. RTV Blue will be fine. A good portion of tractor components are put together with RTV or some silicon gasket material. My suggestion is that you clean the groove if the gasket is round compressible o-ring type or if it is just flat metal to metal. Once cleaned then you would want to put a nice thin bead of RTV and let it skin and dry out a bit, kind of less sticky to touch, then you put it together and tighten the valve cover equally by criss cross tightening the nuts. Don't tighten it too much for RTV to entirely ooze out.
/ Ford 1210
Ok thank you JC-I’ll be doing that after Father’s Day 👍i appreciate your advice
/ Ford 1210 #10
it is
Well, Happy Father's day to you and all the dads out there.
I know I took my valve cover off for rocker arm inspection. I just cannot remember if it had a flat gasket or an oring in the groove on valve cover like most Japanese cars. I could not locate it in my picture library. I know for sure that I did not change any gasket there. you might need to tighten to stop the leak. I would inspect it as you might have tear in the gasket or oring. in any case a thin layer of RTV blue only helps to seal and has no negative effect.
/ Ford 1210
Happy Father’s Day to you also JC-yes sir i already looked at the valve cover nuts and put a socket on them-they were tight-looks like there is no gasket or maybe it’s swashed i really can’t tell by just looking at it
/ Ford 1210
Hey JC I’ve got the valve cover gasket out and cleaned up-do i leave the old O ring gasket in place and silicone over it or remove it then silicone the cover-thank you again
/ Ford 1210
Sorry about that JC-i meant value cover off
/ Ford 1210 #14
is the gasket Flat? or is it o-ring type? if it is flat by all means you can lightly clean gasket material it with a light de-greaser. I would let it flat between two card board with news paper with some light weigh for it to dry out but maintaining shape. After it dries our then I would smear a think coat on one side, let skin and put it on the head (put the sticky side down. Then I will put a thin layer on the opposite side, facing up, let it dry out a bit and then put the cover back. tighten and torque the head in a criss cross fashion. let me know if it is round rubber o-ring type gasket. depending the size I also make gasket hard to find from a sheet of gasket material and transfer the layout and cut it out.
JC,
Fel-Pro gasket sheet
/ Ford 1210
It’s a o ring type-i removed it and cleaned up the cover-then put atv blue in place of the o ring gasket-it’s on the tractor I’m giving it 24 hrs to dry before starting-I’ll keep you posted-thank you again for your advice 👍
/ Ford 1210
JC,
Hey JC the atv blue fixed the gasket leak-thank you for all your advice 👍
/ Ford 1210 #17
I think you're good to go specially waiting 24 hrs for it to cure. It will be a brand new gasket material.
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
Genie Z60 Articulated Boom Lift (A64047)
Genie Z60...
2021 Dodge Durango SUV (A61569)
2021 Dodge Durango...
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
2018 Seadoo Jet Ski (A61166)
2018 Seadoo Jet...
