Ford 1210 Fuel Problem
/ Ford 1210 Fuel Problem #1
ALB
Cumming, Georgia
Ford 1210
Hello, I just bought a Ford 1210. It ran great for the few times i cranked it but now i can't get it to crank. I noticed the fuel shut off valve was on C. Should it be on O? I'm not sure what that means.
thanks for your help.
/ Ford 1210 Fuel Problem #2
Probably means Closed and Open. If true, obviously you want it open to run the engine. If you have run it out of fuel, then you will probably have to bleed the air out of the fuel lines, unless it may be a self bleeding system. I'm not familiar with that tractor, so you might post it in the Ford New Holland forum.
/ Ford 1210 Fuel Problem #4
Let me know if you need help priming the system. I have a 1310. They should be the same.
Thanks. I ran the battery down so i need to charge it up to try it again. I'll put the fuel valve on "O" this time and try it.
Thanks for all the help. Turned out ot be a stripped thread at the fuel pump and i wasn't giving it any fuel.
CHRYSLER V8 GAS ENG (A63291)
CHRYSLER V8 GAS...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
