Ford 1210 Fuel Problem
/ Ford 1210 Fuel Problem #1
ALB
Cumming, Georgia
Ford 1210
Hello, I just bought a Ford 1210. It ran great for the few times i cranked it but now i can't get it to crank. I noticed the fuel shut off valve was on C. Should it be on O? I'm not sure what that means.
thanks for your help.
/ Ford 1210 Fuel Problem #2
Probably means Closed and Open. If true, obviously you want it open to run the engine. If you have run it out of fuel, then you will probably have to bleed the air out of the fuel lines, unless it may be a self bleeding system. I'm not familiar with that tractor, so you might post it in the Ford New Holland forum.
/ Ford 1210 Fuel Problem #4
Let me know if you need help priming the system. I have a 1310. They should be the same.
Thanks. I ran the battery down so i need to charge it up to try it again. I'll put the fuel valve on "O" this time and try it.
Thanks for all the help. Turned out ot be a stripped thread at the fuel pump and i wasn't giving it any fuel.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
METAL SIDES FOR HARDEE TRAILER (A63291)
METAL SIDES FOR...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
HUDSON BROTHERS TANDEM AXLE TRAILER W/2' SIDES (A63291)
HUDSON BROTHERS...
ARTS WAY PM25 FEED MILL GRINDER MIXER (A63291)
ARTS WAY PM25 FEED...
Caterpillar 980G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 980G...
