Ford 1100 rear axle leaking.
   / Ford 1100 rear axle leaking. #1
Trp36
Hot springs, ar
Ford 1100
Recently I purchased a ford 1100 and bush hog for 400 bucks. I got it home changed the fluids and filters and have been usin it ever since. I noticed I have a leak around the axle on the right rear tire. I purchased the seal but now I'm having trouble getting the axle out. I wasn't sure if there was a trick im missing or what? Thanks
   / Ford 1100 rear axle leaking. #2
you did remove the housing and then remove the axle nut?
Thanks I've gotten to that point but I can't seem to get the axle to come out of the housing after I've removed all that. I wasn't sure if there was a trick to it or not. Also the gaskets were bad on the housing is this something you can use gasket maker on or do I have to order them through new holland.
   / Ford 1100 rear axle leaking. #4
If you get it good and clean and dry, I'd think gasket sealer would be OK, you might check with CNH and see just how much the gasket is, might not be able to get it any more! As far as getting the axle loose, I'm sure it will take more than a slight tap to get it to come out of the housing, looks like you might need to also take #4 loose as it kinda looks like the bearings are going to come out with it.
Ok thanks what's the best way to try to tap it out without damaging the threads on the axle?
   / Ford 1100 rear axle leaking. #6
If it were mine, I'd screw the nut back on until flush then use a piece of wood between the hammer and the axle/nut.
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A50323)
2016 Ford F-550...
Deere 317G (A50120)
Deere 317G (A50120)
RSC 45" ELECTRIC LIFT (A50322)
RSC 45" ELECTRIC...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
Poly Round Bale Ring (A50515)
Poly Round Bale...
